Can't quite figure out what I'm supposed to do here. I saw the letter in the greenhouse, got the nightmare vine and the elixir of mental strength. I'm stuck in the room where you get the elixir, I can get by the guard in the hall outside with invisibility, but I can't get through either of the 2 doors there. I'm assuming the templar's room is on the other side, but I'm at a loss as how to proceed.
Long time since I did this quest. But I seem to remember having to cross the main hallway and go up some stairs on the other side. Should be showing on local area map. Hopefully someone can give a better solution if this did not help.
I'm stuck here as well. What as the solution?
EDIT: on the same level of the great hall that you enter on, on the opposite side of the hall there is a bedroom. Read the book.
I have problem in this quest.
I have found 2 ingredients but third is missing. According to arrow on map, it should be in side tha alchemy laboratory, but I just can't find it. There is one drawer locked and it needs key tough, but where could the key be then? Any help?
Thanks, will check that out
Think im being a bit daft, but where on earth is the key to get through the grates to the elixir of mental strength? Im guessing its obvious and im missing something obvious
