4 posts • Page 1 of 1
There is a building near the LIbrary in Treomar called the "Storage Annex". Inside I found a magic symbol and a number of rooms layed out in a star-like pattern. It seems that a stone wall is blocking access to two of the rooms, however. I can't figure out how to get these walls open. Is this something you come back to later? I am in Treomar now as part of the main quest to enter the LIbrary.
That 2 chambers are part of a quest you get in erothin.
Its part of the quest you get from a rich guy in Erothin, so I'm not sure if you can break the quest if you dont have it. But you should light the bunsen burners in each of the side chambers. You probably wont be able to do it if you dont have the quest, just like with the glider.
OK,
Thanks guys. I figured it was something left for later so I put a Mark on that site so I can quickly go there when I get the quest from the "rich guy" :). I've actually gotten his first quest but haven't done it yet.
