2 posts • Page 1 of 1
Hello, congrats and thanks for the fantastic game.
I ran into an issue at the fight with the
[+] Spoiler
Black Guardian
. When the constructs are rapidly killed while still inside their spawning chambers, the chambers fail to close in order to progress the fight. I was confused for a while but when I understood this I moved the bodies and only then the fight progressed normally.
So I was able to get around the problem, but I suppose someone else might run into this as well. You might want to look into this or to leave this workaround public.
Thanks for reporting the problem and for the possible solution, but there will be no more patches from SureAI after all these years.
We are busy with the development of other games, but maybe there will be someone who can fix the cause and make it accessible via mod.
PS: for spoilers there must be a title after the =, otherwise the command will not work (I have changed your post for this)
