1 post • Page 1 of 1
Nehrim and xOBSE
Post by maczopikczo »
I remember that a few years ago Nehrim had no problems whatsoever with OBSE. Now I've decided to play it again, so I downloaded NehrimInstall_1.5.0.8_EN.exe (from GOG, if I remember correctly), and xOBSE from github, because a few newer - as well as the usual older mods, such as OBGE Liquid Water, and All Natural - require it to work as intended. However, I've noticed that even though I've installed xOBSE the right way (same as in Oblivion), the game won't recognise it. I can launch the game via obse_loader.exe, but mods send an alert that OBSE is not present, and saves miss the .obse version. Are you aware of such an issue, and if yes, is there a solution I could try?
Edit (but I'm not deleting the topic in case if someone else makes the same mistake)
It turns out I've rushed things too much. Rather than run the game once via the original launcher I proceeded right away to launching it via the OBSE launcher. Running the Nehrim launcher fixed my issue. Everything works, and I can't wait to play Nehrim to the end for once ;P
