4 posts • Page 1 of 1
Save Files
Post by Squeeks »
Are there any plans on making the autosaves condense? Having so many autosaves is time consuming when trying to go through to find a save file to overwrite. Any insight would be welcome ^^ Thank you for your response!
Re: Save Files
Post by overdev »
Hi :)
Do you play the regular version of Enderal or the Special Edition?
For both of them, you can change in what situations the auto saves are created in the launcher settings under "Game" or in the in-game settings under gameplay.
You can change the autosave limit in the .ini
It depends if you play the regular edition or the Special Edition of Enderal.
For the regular (LE) version go to "Documents\My Games\Enderal", for the Special Edition (SE) "Documents\My Games\Enderal Special Edition".
In both cases, open the Enderal.ini and look for "iAutoSaveCount="
it should be under the entry "[SaveGame]" in the Enderal.ini file.
Everything without the quotes of course :)
LE has a default limit of 5 and SE a limit of 10. You can change the number to the one you like.
But in general, I would highly recommend creating new manual saves regularly :)
Re: Save Files
Post by Squeeks »
:thumbsup: :thumbsup: :thumbsup: Thank you for your quick response! ^^ I had forgotten about the .ini file! Thank you for the reminder and the quickness of your response! I really appreciate it ^^! Now, hopefully, it will only make 3 saves and not 100 per day. I will check the save files after I play today to let you know how many are actually saved in the file as well. :thumbsup: :thumbsup: :thumbsup:
Re: Save Files
Post by Squeeks »
https://postimg.cc/wty4Wtpz/4b3be74b
This is what I'm talking about as well.
