Therefore I could not finish the installation of Enderal. I don't know if my BitDefender Total Security blocked it, but no warning was issued by the program, like it usually does, so i can make exeptions.
welcome to the forum
the pinned support thread states some ways to solve this:
hope that helps
No server connectionIf this does not work:
- Our patch and download servers are always online.
- Make sure to run the launcher as admin.
- If the launcher displays that our download servers are offline, check your internet connection first. If your connection is stable, but you are still not able to get a connection to our patch servers, try to set the Enderal launcher as whitelisted on your firewall or your anti virus program. You probably have to restart the launcher, otherwise it may not detect changes on your firewall or anti virus program.
- Port 80 must be free and available to use for the launcher.
- Untick and tick the online mode checkbox again in the launcher's update window, the launcher will try to connect to another domain.
- Wait a few minutes, the server might be busy (especially on patch days).
- Restart your PC and run the launcher as admin.
- Do you use VPN? It might help to deactivate or activate it.
- Press [WIN] + [R] to open up run dialog box.
- Type in cmd.exe and confirm with [ENTER].
- Then type the following: netsh winsock reset and confirm with [ENTER].
- Restart your PC.
- Start the launcher as admin and try to download the patches again.
Solved, by adding it to the whitelist and running it again. Now the update proces works! And
thank you for the response, good to know it works now
have fun playing
have fun playing
