3 posts • Page 1 of 1
Hi, my issue is this everytime i try to use the in-game map Enderal crashes without fail, and i have no idea why, i don't have a single mod installed(apart from actual Enderal), i hope it's fixable..
https://gyazo.com/a4e0ea65898baadaeb6c6669cd16322f
Which language do you use for your operating system, which for Skyrim and which for Enderal?
Which version of Enderal do you use? Do you have the latest updates?
I can not recognize the error message because I can not map the language.
What kind of system do you have? (Hardware and Software?)
Enderal looks english, system seems to be swedish?
error message is just windows saying, "Skyrim stopped working correctly..."
absolutely not helpful, as Windows messages usually are ;)
when did the issue show up?
are you playing for a while and that started just now, randomly,
did you patch to the latest Version and it started with that, or
is that a completely fresh install and you just started playing?
delete the two *.ini from ...\Documents\My Games\Skyrim and restart the game
(it will create a new one on launch)
that might help
you also could take a look at the skyrim.ini (in that folder) and search for the lines
[ScreenSplatter]
bBloodSplatterEnabled=0
and delete that.
NO idea, why it would be there, but google says it's responsible for map crashes.
(for whatever reason)
hope that helps :)
