6 posts • Page 1 of 1
Before I escaped the mining cave, the mage asked me bringing a letter to master who live in abbey. When I finally met this master and tried to talk with him, the subtitle showed "I have nothing to say".
Pretty annoying, cause I've tried several times.
How can I fix it? :cry:
thx
hi there (sorry for the late reply D: )
what does your questlog say?
did it update to
"I arrived safely in the Abbey." ?
do you have any mods installed/tried any cheats before your arrival there?
(fast travel for example could cause issues)
you probably tried earlier saves -
from what point on? can you load a save that allows you to walk back into the area of the abbey?
last resort would be console commands:
setstage MQ01Porim 30 ---> ensures you got into the abbey (queststagewise)
setstage MQ00 65 ---> the stage after your talk with the priest; your're then save to head to the sanctum
did it update to
It's fine. I cannot play any game until next weekend. Your reply is timely. :lol:
My quest log did update to "I arrived safely in abbey", and no mod no DLC no cheat. ( if console commands are cheats then yes i used "tfc") ( fast travel? Turn all map markers? No, I didn't do that.)
My last save was at the beginning of the game...I'll try to load it when I go home. I remember I did arrived abbey by feet.
Thx for these commands. And I appreciate your help!
:D
well tfc really shouldn't be a problem here :D
sounds like a typical "reloading solves it" bug
oh hell
for your own sake, try to get used to saving a lot more, and on different saves, not just one.
not just because of bugs, Nehrim will crash.
in this case..
yeah. reloading, trying again. not much else to do, sadly - except for console commands (which could make things worse)
not because of bad programming, don't get me wrong - mostly Oblivion engine really :|
Problem is solved! :lol: Indeed it's a save/load problem. Thanks for your helping, thanks a lot! :lol:
good to know :)
and as said - save often, save early -
only every half an hour just leads to frustration ;)
