8 posts • Page 1 of 1
Books and Mem points?
Post by The Pawn »
Greetings All,
If books raise you stats then why do I need Memory points.
Thank You
Deleted User 23162
Re: Books and Mem points?
Post by Deleted User 23162 »
Memory points are for perks. Books are for skill level.
ok tnx
Deleted User 23162
No problem. :)
Greetings All,
can you respec in game?
I use a gamepad and I found out you can see all your skills with a mouse over but not with the gamepad.
I mean the area with all your stats and how many more points you need to next level.
Would not have made some of my choices if I had known.
Thank You
Nope, not at the moment.
You should be able to map the "Hero menu" on your gamepad/controller by heading into the ingame menu [ESC], than open up the "modification configuration", and then click on "Enderal". There should be the option to change the button/key.
I know that but you cant scroll over each skill like you can if you use a mouse ,it doesn't show you each item in the 3rd screen the one with big circle.
Thanks
Deleted User 23162
Consoles are the devil. :P
Perhaps the directional pad still needs to be implemented for that area?
