Whenever I go somewhere high on a hill or mountain, where the high speed wind fx are used, the sound will follow me around and will not go away unless I exit the game. But as soon as I go somewhere that has that sound...rinse and repeat. I did everything I know to stop that but unfortunately was unable. I have a newer system msi 970mb, fx8350, gtx 660sc, realtek hd audio, 8gb ddr3 1866. I tried 3 other audio drivers for that chipset and well, it continues.
Am I alone on this or is there something else going on? Please help if you can.
Do you have high FPS or do you use a 120hz/144hz monitor?
If yes I would recommend to use a FPS Limiter and cap it at 60. The Engine can't handle high FPS.
I have it set to 60 fps through evga precisionX16. With the realtek HD audio there is the creative soundblaster cinema 2 app that does nice things for movies and music but it conflicts with the system equalizer i have installed. Both edit the same 2 .dll's. I removed the SB cinema and use the eq program instead and the issue is fixed.
The EQ is excellent and I recommend highly especially if you like having sub bass frequencies below 18 hz come alive. using the peak filter and q factor/gain. 31 band eq. Free and fully functional, seriously. 32 and 64 bit versions. DL here;
https://sourceforge.net/projects/equali ... les/1.1.1/
