stinkoman247 wrote:Streamline! Its desperately needed, with all of nehrim's hyper lag. Ive tried but no success so far. If you wana help, check the streamline for nehrim: need help thread.
ibbeebee wrote:Deadly reflex 5 is already converted to work with NehrimOtori wrote:-Deady Reflex 5
-Real Hunger/Real Thirst/Real Sleep
-Sprint Mod
http://planetelderscrolls.gamespy.com/V ... il&id=6465
Just install Deadly Reflex 5 & copy over the ESP it works fine & if you do a search on this forum you will find other references to it Beebee
Can you up again?
To TESNexus maybe? ;P
I have a request for the "non glowing enchanted items" mod. I downloaded the new version and it seems to not work with the older version of the no glow mod. If anyone can fix that for me I would really appreciate it.
Nevermind found out it was the load order for the game...
Anyone willing to take a look at this and see if it can be converted over to Nehrim? http://www.tesnexus.com/downloads/file.php?id=19847
It has a voiced and non voiced version I was thinking the non voice one would be where we start since the voiced one is English and this mod is German voiced. He said I could convert it but I have no idea where to even begin to try converting it. I have 0 coding and 0 mod making experience myself so that's why I am asking for your guys help on this. i would like to see this mod converted over to Nehrim.
Androktone wrote:Yes, HGEC doesn't need conversion because it contains only meshes and textures but that doesn't mean all other similar modifications work the same. For instance, Robert's Male Body Replacer has also an .esp file, which needs change of its master.Pyryp wrote:You can use HGEC and all others without conversion.
I also recommend Ozmo's High Rez Skin Textures for HGEC, including also textures for Ren's Mystic Elves used for Nehrim's Half-Aeterna.
http://www.tesnexus.com/downloads/file.php?id=34444
any one wanna take a stab at this race add-on? ive tryed 5 times thus far to no avail. thank every one in advanced =)
I tried to change the master file of streamline 2.1 but now I don't know if it works or not, in game appeared a ring which if clikked I can change the level of aggressiveness of streamline, it is the definitive proof that streamline is working?
can someone convert duke patrics archery mod http://tesalliance.org/forums/index.php ... t-archery/
bill2505 wrote:can someone convert duke patrics archery mod http://tesalliance.org/forums/index.php ... t-archery/
but it also needs obse.how do you install obse.the same as in original oblivion
