Run the launcher as administrator. Remove write protection in your Skyrim directory.
Please attach you LauncherLog:
C:\program files(x86)\Steam\steamapps\Skyrim\EnderalLauncher\system\log\launcher
slowik1987 wrote:Ok guys i think i know what the problem is. You need to have Steam installed. When I unistalled steam for a moment because i had an idea the error Enderal has stopped working appeared. When I installed steam back it worked again so there you have it
Maybe i will update the OS from 7 to 10 on the weekends. Worth to try.
do you any of you got a clean install of skyrim withough any documents inis saves or whatever?
Dude, I think most people, myself included, installed Skyrim specifically to play Enderal, so yeah, most of us do, I imagine.
I had the same problem but just now fixed it myself.
To get the launcher running, you need to execute the .exe via cmd.
> run cmd as admin
> type in: cmd /K "folderLocation\Enderal Launcher.exe"
> mine looks like this cmd /K "I:\Steam\steamapps\common\Skyrim\Enderal Launcher.exe"
That should do it, worked for me at least
> run cmd as admin
Well, that actually almost did something.. there was a little jerk of the screen and that windows 'loading' icon instead of the cursor, but no luck again. Well, gawd damn.. thanks anyway dude, maybe you're onto something
To run the launcher make sure you have .NET Framework 4.5 installed.
If it creates a LauncherLog it would be great if you could attach it.
Otherwise ou launcher programmer has to look into this problem.
Yeah, 4.5 is installed.. where would this log be, in the same directory? If that is the case, I am afraid there is no log.. I guess that makes sense since I think the launcher actually does not ever launch.. it does not crash or anything, just never gets to the stage where it is loaded..
Aplicación: Enderal Launcher.exe
Versión de Framework: v4.0.30319
Descripción: el proceso terminó debido a una excepción no controlada.
Información de la excepción: System.NullReferenceException
Pila:
en Launcher_01.cs_Functions.workingDirectorySearcher(System.String)
en Launcher_01.cs_Functions.FormFunctionsLoad()
en Launcher_01.mainPan..ctor()
en Launcher_01.cs_Program.Main()
that's what happens when I try to open the launcher. My Skyrim is not intalled in the steam directory because the route was too long for creation kit to find the many resources I have installed. Could it be the reason? Does it only works when it's in that specific directory?
Pila:
