Almost forgot I should post the updates ck.bat file. Just a bit too busy with too many other things.
A guide for the use of this batch file can be found in the guide sections of both Enderal and Skyrim.
Thanks again, Screwball, for your suggestions. I have incorporated your suggestions in the batch file.
ck.zip
(568 Bytes) Downloaded 454 times
It has been a while since I posted here about the Creation Kit and Enderal. I have recently acquired a new PC with Windows 11 and running Skyrim SE version 1.6.1170 and Creation Kit 1.6.1378 with the Creation Kit Platform Extended. I have adapted my batch file accordingly, and that works fine. I have also tried to add some of my own mods to Enderal SE, but for some reason these don't show up in game, although Wrye Bash (v3.13), LOOT and EnderalSEEdit (v4.15f) confirm the mods are installed and do not display any errors or other inconsistancies.
I presume Enderal SE still needs the older version of the Creation Kit, right? Does anyone know of a workaround?
hello Altbert
I haven't used Wrye Bash and co for years and can't contribute much to Enderal-SE-Modding myself,
but check out our SureAI-Discord for more info,
if you can't find it on NexusMod's
or in the Discord of the creator of the SE version (Eddoursul ) alternatively
20.02.2025 20:53Stefanie wrote: hello Altbert
I have already solved the issues, shortly before your response. The only thing required was to install B.E.E.S. (Backported Extended ESL Support).
I was in for some big disappointments today. I thought B.E.E.S. was the solution to my problems, but it wasn't an overall solution. I could add Skyrim SE mods to Enderal SE by stripping Cell and Worldspace records, replacing those with Enderal Cell and Worldspace records. But, compiling scripts doesn't work for one bit. Just replacing one single value in a script causes the compiler to produce a sh*t load of errors.
Over to Discord for a post-Steam version of Enderal SE, but ... it requires Mod Organizer? Why? Does the whole gaming community only use MO, not Vortex or Wrye Bash?
The SureAI team did a wonderful job with Enderal and the other TES based games, but I am completely done with Enderal SE, at least with the Eddoursul version of it.
From what I understand, Vortex is rather niche and Wrye Bash is special, but rarely used. Most people today use MO2, which also has the most support.
22.02.2025 00:43Stefanie wrote: From what I understand, Vortex is rather niche and Wrye Bash is special, but rarely used. Most people today use MO2, which also has the most support.
I think we are misunderstanding each other, Vortex is not generally excluded just because there is no special support for it from us
(SureAI itself does not support mod's or mod-managers directly anyway, that would have to be done by the actual program- or mod-creators, not us).
I don't use Vortex, for example, so I don't know anything about it.
Of course you can also use simple mod´s via Vortex and Co or even install them manually / without a manager.
Maybe automated mod lists are something else? But someone in the mentioned Discord's will probably be able to help.
Why xEdit should not work is not quite clear to me, I have created mod's myself and also worked with SSEEdit in EnderalSE,
but I have installed my own mod´s manually and then edited them,
or used MO2 for many third-party mods without xedit. Maybe mod-manager and XEdit are a problem?
But MO2 is not hard to use, you just shouldn't try to use Windows 7 or 8 with it, but at least Windows10.
As I said, if you want to use Eddoursul's version and not Steam / SureAI's, just contact him directly or his Discord if you have any questions or suggestions.
If there is any misunderstanding and to be clear, this new Enderal SE can't be started without using MO2! Anything I tried to circumvent MO2 was a NO GO! If I would try to circumvent MO2, it would just load Skyrim SE, not Enderal SE, which in my opinion is an infringment. Skyrim SE should never be able to load outside the default Steam location. This game requires MO2. The folder structure is different from the the standard Steam folder structure, which prevents utilities like xE#dit to recognize it. Creation Kit ini files require version control to be disabled, but when disabled, stil requires to disable it.
Although I don't like MO2, I know how to install mods with it. I'm not a complete nood! I use Wrye Bash as a mod manager ever since Morrowind and it suits me very well. I have no intention to change to MO2, Vortex or whatever other mod manager. but requiring MO2 for launching the game?
It has even got worse!
"Version control is enabled. A network location must be selected to proceed. Select OK to locate a ConstructionSetNetwork.ini file and continue."
If I select Cancel, the following message appears:
"Version control can be disabled by setting bUseVersionControl to 0 in the ConstructionSet.ini or CreationKit.ini file."
This is what I have learned sofar about Eddoursul's Enderal SE:
- Using MO2 is a hard requirement
- xEdit doesn't work without a workaround (xEdit is working for me now as I have found a workaround)
- The CK needs a network connection to disable version control (network connection to Eddoursul's Discord?), setting bUseVersionControl=0 in the CK doesn't have any effect
- Use of a different folder structure, which prevents the use of external programs like xEdit, LOOT and Wrye Bash (the latter is important to create Bashed Patches, and I know the LOOT API is included in MO2)
- Enderal SE support now in the hands of Eddourul at Discord (great, but not really!)
