23 posts • Page 2 of 3
paulus_romanus wrote:
The thing is that I used the "add URL" option.
Then I'm not sure, maybe try downloading just the torrent file as it's very small and then add torrent that way via your torrent client.
Sorry not more help :(
Just checked clicking the link provided by Xagul and it downloads the .torrent file and my torrent software qbittorrent automatically started.
I've attached the actual .torrent file, try download this and then starting the torrent from your client
EnderalInstall_EN.torrent
(20.22 KiB) Downloaded 142 times
But that is my problem , because when I go to http://dl.enderal.com/ if I use the torrent option it redirect me to http://torrenten.enderal.com/
Download the file attached to my last post as this is the .torrent file that your torrent software is looking for....and hopefully this might help
Thanks, but could you do the same with the launcher? becuase it redirects me http://launcheren.enderal.com/
I did not saw your reply!!!
Thanks, but could you do the same with the launcher, becuase it redirects me http://launcheren.enderal.com/
I really hope this allowed and as the forum will not allow .exe due to the risk I've zipped it...so extract and run after the .torrent has finished downloading and you have put both in your skyrim folder
Enderal Launcher.zip
(2.57 MiB) Downloaded 126 times
Man! You saved my day!
A thousand thanks
@paulus_romanus I suspect there is a setting with your browser that isn't allowing downloads as both these links automatically download the required files.
But if this is working, that's the important thing for the moment... Hope it all works and enjoy 8)
A thousand thanks
Damn... I've done something right today... Many thanks to you as well indeed :thumbsup:
Enjoy the game and just remember to stick the launcher (extracted) in the skyrim foler and the data from the .torrent (don't extract it) in the same skyrim folder before running the launcher and if it asks you where the .gz file is just browse to the same skyrim folder.
Good luck
@paulus_romanus as requested via pm (no attachments allowed in pm) a new download and zipped (using 7zip saved as basic .zip and tested ok) of the enderal launcher.exe
Fingers crossed and good luck
Un-zip, place in Skyrim folder, right click and run as Administrator...just to be safe
(2.53 MiB) Downloaded 119 times
Edit... to test I've just downloaded and run this from inside the zip and this is the message you'll get if you forget to move it to your skyrim folder as seen in the image.
Quick question, do you have your Skyrim in the Steam folders ?
Image of the downloaded file from this post working
Edit 2.... does Skyrim launch from Steam happily, as I don't know but might be worth checking that it's working as if that's not running it could be why the launcher fails as (I believe) it checks that it's in the same folder as Skyrim with some method that muight require a Skyrim that has run at least once to register it's location in the regisrty... this is just pure guesswork, but double check that your Skyrim is working if this launcher isn't working for you
