74 posts • Page 2 of 8
I have the same problem. Launcher doesnt work.
I am also unable to get the English launcher to execute. No error messages or noticeable task processes in the task window even for a short moment of time and no folder creation upon execution. Verified all requirements. Framework 4.5, and tried executing in all compatibility modes as administrator. Just for testing purposes I downloaded and was able to start an older German version of the launcher that had been posted in an older thread with no issue.
Well this is good news, must be something with the english launcher, then.
same here but i got only 37 gigabytes on my ssd also
iwant to know if this needs a clean installtion of skyrim or skyrim legendary withough any ini alterations or shitload of mods enbs
also what about skse im trying to understand what laucher do at appdata then fail same error with german laucher
C:\Users\razien\AppData\Local\Temp\WER2D8.tmp.WERInternalMetadata.xml
C:\Users\razien\AppData\Local\Temp\WERAB6.tmp.appcompat.txt
C:\Users\razien\AppData\Local\Temp\WERAC6.tmp.mdmp
then fail and crash
Tilliboy wrote:
So, the Launcher worked previously on your computer?
You installed through the launcher i guess.
Could you upload your LauncherLog:
C:\program files(x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\log\launcher
The launcher did not work at all on my computer. Just this error pops up, shown in the link I provided.
Since the launcher has not worked in any versions, I could not install through the launcher. It simply will not open.
I've never posted a log of anything before so if this is incomplete, please let me know. Here is the LauncherLog:
[[ Starting Launcher ]]
Log started at 2016/08/13 19:09:32
If you encounter any issues with the Enderal Launcher this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A39
Release version: Skyrim Classic
Build date: 8/13/2016 7:09:16 PM
Creation date: 8/13/2016 7:08:44 PM
App start location: C:\Users\Trenton\Downloads\
Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
NET Versions: 4.6 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.1.0.0
Internet connection: True
Installation status: False
Steam status: True
OneTweak status: True
Directory search status: True
Last external startup path:
Last external executable:
Backup path Enderal: path
Backup path Skyrim: path
Created an account just to say I solved my problem. Had to disable my antivirus and run the launcher as administrator. Also, the launcher needs to be in your Skyrim base directory.
I just tried that, and it still shows the error message.
I tried everything that its mentioned here.. And I still cant open the "Enderal Launcher" file. I dont get any error message either. Nothing happens when I double click that file. I tried administrator mode, different compatibilities, changing directories, copying all files to skyrim folder.. Nothing works.
for me, I'm having empty folders, anyway to fix that??? its also saying the program files aren't there for the installation package selection
do you have a clean install of skyrim? with no mods no files or saves in documents or tweaked inis?
enbs etc? im gonna do that first you also need the games files from the torrent prefered the things is as isaw in a video after
you open laucher you need to select the game files 7.8 gigs from torrent etc
does any got problem with clean install and firewall exeptions antivirus off and run as admin ? if yes it should be
the problem of the launcher
but as same video said you can put laucher anywhere in your drive it dont matter
