I haven't saved many times, because I havent moved my oblivion saves yet, there are about 500 of them, and I figured that I would just keep 1 or 2 Nehrim saves to keep things organized for now. I will be making another folder for my oblivion saves, and I will save often from now on
Whether the stone fell through the floor, which was my first thought, or is stuck somewhere, or who knows maybe it just never spawned, it isn't there. I have checked thoroughly. I am hoping someone could give me the command to spawn another stone, or tell me the questID so I can use the setstage command to skip this part of the quest. Thanks!
AHA
I've found the stone after using tcl to search around outside the map. It is stuck behind the medium stone, just as I thought. Any tips on how to get it out?
Unless you manage to pull it through the wall with tcl enabled, i have to other idea.
How would I get tcl to affect the stone?
I can target it in console to get its ID?
I'm afraid I can't help you, but I do read about your problem and only one thing comes to my mind:P
It's been unsolved for a while now and my impression is that it would be much easier/faster to simply start again.
Luckily, such a problem occured at the beginning of the game, so it shouldn't be a big deal.
Good luck with the quest!
PS. I really recommend saving, as I sometmes happen to have 'corrupted' quicksaves... The same used to happen in Oblivion.
I finally managed to get the stone free
I had to tcl myself into the little cave where it was stuck and after about 5 minutes of stone adjusting I finally managed to pull it out. I'm having a great time exploring the gameworld, I hope this doesn't happen to anyone else!
Nice to hear that my suggestion worked. If you need help again, just come back. Or simply stay ;p
Bugs like that unfortunately cant be avoided, its the stupid engine thats messed up.
hi all.new here.issue i am having is how do you move the stones to block the rat holes?i can see the stones but when i try to activate them it is telling me that they are too big (or heavy or something) to take with me or move.is my strength not high enough yet for this?thanks
you use the grab command to move the rocks into position. default key is "z".
If you're new to Nehrim, you might find this site useful:
http://nehrim.wikia.com/wiki/Journey_to ... rk_in_Mine
