Casper wrote:luckily, i'm very hard to kill. but it's in my safety deposit box anyway.koschwarz wrote:what if you die in one of your adventures?![]()
your belongings may fall into wrong hands this way...
Leaing it in your savebox is a bad idea. As started in the quest, the Axe slowly manipules the area around it, over the course of several days. If you carry it around with you, always travelling, it wont cause much harm, but leaving it in the box will slowly kill the people around there.
himmelslicht wrote:Leaing it in your savebox is a bad idea. As started in the quest, the Axe slowly manipules the area around it, over the course of several days. If you carry it around with you, always travelling, it wont cause much harm, but leaving it in the box will slowly kill the people around there.
Well Casper you sealed Nehrim's fate once again
then i did well i dropped it in the forging fire deep in that dungeon where it came from
Not sure if putting it in the fire was a good idea, in the Mastersmiths journal it said, the axe absorbed the heat, and the negative effects increased even more. But well, at least its down there where it cant harm anybodt:p
himmelslicht wrote:Not sure if putting it in the fire was a good idea, in the Mastersmiths journal it said, the axe absorbed the heat, and the negative effects increased even more. But well, at least its down there where it cant harm anybodt:p
It would be transforming them into zombies.
The Southrealm got lvl45 zombies? Time to get there, i smell XP *drool*
