This just happened to me, actually. A Steel Bearded Axe (I think, it weights 15 and has attack damage of 10) that I had enchanted with a ice sapphire (out of a ice elemental).
I can try to recover the item by console and enchant again, but what is the id of the axe mentioned above and of the ice sapphire, anyone knows?
Regards
Regards
did you read through the thread?
Oblivion was fully patched before you installed Nehrim, yes?
it would probably be easier to reload an earlier save (if there's a fitting one),
but these are the IDs from the CS
(the weapons are a bit different though, weight 16 and dmg 13?)
the axe should be
the sapphire
hope that helps
the axe should be
Code Select all
BeardedAxeSteel or 19cf67the sapphire
Code Select all
2Eissapphir or 1eda0c26.12.2018 18:15urst wrote: did you read through the thread?
but these are the IDs from the CS![]()
the axe should beCode Select allBeardedAxeSteel or 19cf67
the sapphirehope that helpsCode Select all2Eissapphir or 1eda0c![]()
Nehrim was installed two days ago from my fully updated GOG copy of Oblivion, so absolutely certain it is running the latest. It seems it was what netpolip mentioned:
13.10.2010 12:08netpolip wrote: Only those items disappear, witch is enchanted by the player. But this is happening when you save the game and exit. As long as you play the game, save and load a lot and not quit you do not have this problem.![]()
The axe isn't exactly the same, but it's not that different, I'll use this one.
Thanks again, much appreciated!
you're welcome
let's hope it doesn't happen to often :/
