18 posts • Page 2 of 2
did you try my saved game, because i've never seen that pop-up window. please, have a try with my saved game and tell me if it works or not.
however, thanks for you help. tonight i'll pay attention to what you told me. meanwhile i wait for your check on my saved game
I just tried your save. most likely you have killed the dark troll in the start dungeon the wrong way.
however, just type "set startglobal to 1" (without "") in the console and you should be able to level up.
When I tried it with your save you got instantly up to level 9.
thanks Roland, I'll try
but please, can you tell me how to make appear the console?
To open or close the console press '~' key (the one above Tab)
then type "set startglobal to 1"
then press enter
I can only confirm what Roland Deschain said. This will be fixed in 1.0.8 (no more way to kill the black troll "the wrong way") but you still have to write "set startglobal to 1" into your console in order to make the diary usable.
Thank you Roland.
It worked! Now I can enjoy the game better.
If that is solved, then I have another question. I am completely unable to level up - the game allows me to open the diary, I press "Level Up", select attributes... and when I press OK, the game flat out freezes. I've tried it several times, no luck. What could be wrong? Save game attached. It's a pity if I can't keep playing because I was really intrigued by the introduction and would like to get out of the mine and explore! Thanks for any help :)
Alarion
quicksave.ess
Save after I killed the troll in the cave
(452.23 KiB) Downloaded 164 times
Actually, disregard that. I found the solution here http://www.sureai.net/forum/viewtopic.php?f=87&t=2969
Apparently I just needed to wait a bit longer and not be so impatient once I get into it ;)
Thanks anyway for making such a cool game mod!
//Alarion
