Ok i moved it and it still wont let me remove the read only it keeps going back to read only every time i change it.
That is normal. Windows always shows the checkmark again even if you remove it.
And Launcher as Admin does not work?
No its not working admin wont do anything and please don't say reinstall cause i have done that a hundred times.
My question is why wont the text for new game come up the "explore enderal" something has to be wrong there.
[General]
sLanguage=ENGLISH
sIntroSequence=1
uGridsToLoad=5
uInterior Cell Buffer=6
uExterior Cell Buffer=36
iPreloadSizeLimit=2684354560
[Display]
fLightLODMaxStartFade=3500.0000
iShadowMapResolutionPrimary=2048
bAllowScreenshot=1
fDefaultWorldFOV=75
fDefault1stPersonFOV=75
[BackgroundLoad/Multithreading]
bLoadBackgroundFaceGen=0
bLoadHelmetsInBackground=0
bBackgroundLoadLipFiles=0
bBackgroundCellLoads=0
bUseBackgroundFileLoader=0
bMultiThreadBoneUpdate=0
bUseMultiThreadedFaceGen=0
bUseThreadedParticleSystem=0
bUseThreadedTempEffects=0
bUseThreadedTextures=0
bDecalMultithreaded=0
bUseThreadedBlood=0
bUseThreadedMeshes=0
bUseMultiThreadedTrees=0
bUseThreadedLOD=0
bUseThreadedAI=0
bMultiThreadMovement=0
bUseThreadedMorpher=0
[HAVOK]
iNumThreads=2
iNumHWThreads=2
[Audio]
fMusicDuckingSeconds=6.0000
fMusicUnDuckingSeconds=8.0000
fMenuModeFadeOutTime=3.0000
fMenuModeFadeInTime=1.0000
[Grass]
bAllowCreateGrass=1
bAllowLoadGrass=0
[GeneralWarnings]
sGeneralMasterMismatchWarning=One or more plugins could not find the correct versions of the master files they depend on. Errors may occur during load or game play. Check the "Warnings.txt" file for more information.
[Archive]
bInvalidateOlderFiles=1
sResourceArchiveList=Skyrim - Misc.bsa, Skyrim - Shaders.bsa, Skyrim - Textures.bsa, Skyrim - Interface.bsa, Skyrim - Animations.bsa, Skyrim - Meshes.bsa, Skyrim - Sounds.bsa
sResourceArchiveList2=EEN - MeshesLOD.bsa, EEN - Meshes.bsa, EEN - Music.bsa, EEN - Scripts.bsa, EEN - SoundFX.bsa, EEN - SoundVoice.bsa, EEN - SoundExtra.bsa, EEN - TexturesLOD.bsa, EEN - Textures1.bsa, EEN - Textures2.bsa, EEN - Textures3.bsa
[Combat]
fMagnetismStrafeHeadingMult=0.0000
fMagnetismLookingMult=0.0000
[Papyrus]
fPostLoadUpdateTimeMS=500.0000
bEnableLogging=0
bEnableTrace=0
bLoadDebugInformation=0
[Water]
bReflectLODLand=1
bReflectLODObjects=1
bReflectSky=1
bReflectLODTrees=1
[VATS]
bVATSDisable=0
fShadowLODMaxStartFade=1000.0000
fSpecularLODMaxStartFade=2000.0000
iPresentInterval=1
SGeneralMasterMismatchWarning=One or more plugins could not find the correct versions of the master files they depend on. Errors may occur during load or game play. Check the "Warnings.txt" file for more information.
Now if you see what i see at the bottom then we know something is wrong there.
sLanguage=ENGLISH
sIntroSequence=1
uGridsToLoad=5
[Display]
bAllowScreenshot=1
fDefaultWorldFOV=75
bUseThreadedBlood=0
bUseThreadedLOD=0
bUseThreadedAI=0
[HAVOK]
iNumThreads=2
iNumHWThreads=2
[Audio]
[Grass]
bAllowCreateGrass=1
bAllowLoadGrass=0
[GeneralWarnings]
[Archive]
[Combat]
[Papyrus]
bEnableLogging=0
bEnableTrace=0
[Water]
bReflectLODLand=1
bReflectSky=1
bReflectLODTrees=1
[VATS]
bVATSDisable=0
iPresentInterval=1
the
doesn't have to mean anything.
(I think that's even present as soon as the file is created
but
the masters seem off (I could be wrong, I should write the english ones down some time)
navigate to ...\Steam\SteamApps\common\Skyrim\Data
that's where the data files are stored, EEN-xxxxx.bsa beeing the english masterfiles.
does this list in you ini
match with these files?
[GeneralWarnings]
but
Yes i got all those any ideas what maybe going on cause i got nothing.
I got all the skyrim.bsa files to is that ok.
yeah, Enderal need them as well
what exactly did you mean by
where did you copy that from?
...someone else did that is copying the skyrim.esm file to the data folder...
