Chiobe wrote:I give up.
Anyone know the quest code, so I can just skip to next part?
Might not be as easy as setstage. As you can imagine, bunch of other stuff going on in background & lots of fragments.
Tilliboy will have final answer. Touched base with him before being "Mr. Helpful" here, and his only request was *not* to post anything code related because (as said) he's updating it!
All posts here get read though, so am sure you'll have an answer.
Am curious though, after checking in CK. Are you able to console and get quest & stage are you at? What does the objective say? If you're where I think you are...
...You are somehow *below* a collision plane and falling into a killbox before you can get to a quest update box. : 0 !
But you knew that. : /
If fast enough opening console, am guessing you've already tried TCL. If not already in "PlayerKillOnEnter" zone, could try moving you to a reference marker, but again.... Need more info., or kick back & wait for Tilliboy (recommended.)
fwiw
--Bruce
BigElectricCat wrote:Am curious though, after checking in CK. Are you able to console and get quest & stage are you at? What does the objective say? If you're where I think you are...
fwiw
--Bruce
Writen in the order they came, if that matters.
TIM worked (so scripted death, since TCL and TGM didnt work), but now so did I get a black screen when 1 of them when to collect the Numinos. Had to restart my pc, but progress I guess.
Might have run into the same error and don't have any mods installed.
After one cutscene, bizarre height and no movement or vanity mode. Wondered what was going on.
So "tfc" and I'm sunk halfway into the floor! TCL and can slowly levitate out of floor but am frozen while either falling, jumping or treading water. Keys usless, so tried someone's suggestion from another topic about being 'frozen.' player.resurrect. That fixed it.
Maybe that will help or, as last resort, backup save a "testgame"
;completes quest but may or may not mess up cutscenes, load next quest, etc.
Setstage MQ16 180
;fragment at 180 reads "kmyQuest.StartMQ17()"
;unknown if that will move you to MQ17 stage 5 (objective 5 "Investigate the portal") or just make it worse.
Best!
--Bruce
Edit: Forgot you might be stuck or floating around who knows where!
Here are reference markers.
;player start marker for Numinos
player.moveto 1486A1
;if needed to get you on your feet
player.resurrect
;unused ref marker on a piece of stone to one step forward to your left
player.moveto 132426
Setstage MQ16 180
Best!
--Bruce
player.resurrect
Well, I at least managed to finish the story now, so guess this issue can be dealt with later, unless more people have the same issue.
Chiobe wrote:Well, I at least managed to finish the story now, so guess this issue can be dealt with later, unless more people have the same issue.
Will leave that to dev's... : )
Anyway, glad you were able to finish!
Sorry, I'm late. There are so many other tickets...
If you have a savegame from that certain part of the game (before entering the high one) I would look into this problem.
Thanks.
Thanks.
Tilliboy wrote:Sorry, I'm late. There are so many other tickets...
Thanks.
There, save game uploaded.
Answer is at the bug tracker. Closed.
