I have a similar problem, after the last updates, whenever I try to start skyrim, wether through the enderal launcher or through skse or the regular skyrim launcher, I keep getting the pop up screen saying: Skyrim is preparing to launch, which is repeatedly showing up and disappearing.
I have already tried swapping out the skyrim folder, and then back to the enderal folder, but that regrettably didnt work.
Hey guys,
for those who keep getting that "needs an update" message look at the link below:
http://en.wiki.sureai.net/Enderal:LauncherDebugging
In this case here:
If you do not have your launcher/game in C:, just search for the EnderalLauncher folder in the Skyrim folder.
For the other problems our Launcher programmer needs to look into the issue.
In this case here:
[...] or the launcher displays that everthing is installed but you can't start the game, go to this directory: C:\program files(x86)\Steam\Steamapps\common\Skyrim\EnderalLauncher\system\config.sur. Edit the file (it's a textfile) with e.g. Notepad++ in this way: replace the "sCurrentVersion" with an older version (safest: "1.1.0.0").
No update on this? I still get nothing when I press launch.. Really want to play. Thanks
Try to click on Settings in the launcher and Save setting. It worked for me, its weird.
Reizeii wrote:Try to click on Settings in the launcher and Save setting. It worked for me, its weird.
Raicyk, I have been having the same trouble and this is not a fix for the launcher, but you can launch enderal from your skyrim folder by launching "skse_loader".
I'm having this problem as well. Any ideas?
Hi All
I had the same issue. Was playing just fine when it suddenly crashed out to the launcher and wouldn't start back up. I updated it and it said it needed to 'Restart the Launcher', but it never came back.
Have tried all the suggested solutions. I've already played quite a few hours and don't want to lose it. HALP!!
Since you've listed a bunbch of problems in this thread:
Launcher does not run: Download the newest launcher from our website and overwrite the old one.
Update problems: Wiki page for update problems
installation problem: Uninstall Enderal via Launcher, reinstall Skyrim, verify Skyrim's game cache, download a new installation package (we recommend the torrent), follow this installation guide.
I've found the solution to the enderal launcher running the skyrim launcher: set skse_loader.exe and enderal launcher.exe to run as administrator.
