Having the same issue here as well, but with only ihud and immursive hud installed. Not really sure what's going on. After the discussion and the fade to black happens, it just stays black. I can still hear fire crackling and footsteps.
Edit: After a few tries, deleting a few auto-saves and restarting the game fixed this issue for me. I reloaded a quick save before the fade to black and was able to continue.
Greetings!
I have experienced a problem with the quest "In the Lion's Den" to be exact with the part immediatly after the quest. The screen goes black and stay that way. If there is any additional info that I need to provide, ask away.
Had the same problem, what helped was:
deactivating experimental multithreading options in the launcher.
What also could help is activating OneTweak or lowering HUD Opacity.
Restarting your game/PC also seems to have helped some people.
I had the same issue. Shutting down the game completely and then reloading the most recent autosave worked for me.
I really tried everything whats been suggested. Is there anything else i can do.
Really love the game but cant seem to get any further.
Im trying to attach the skse file but it says : the extension skse is not allowed
HELP
HELP
Save 633 - Blackadder Halfmoon Isle 67.44.28.ess
(4.59 MiB) Downloaded 111 times
blackadder08 wrote:I really tried everything whats been suggested. Is there anything else i can do.
HELP
I added the save after the loadingscreen. You will be confused if you see it, but don't worry it is all fine.
If you encounter audio issues or missing music (not immediately - but later) give me a hint where it stopped playing (known issue - cause unknown).
blackadder.rar
(1.77 MiB) Downloaded 96 times
Hey Tilliboy,
thanks for the trouble but sorry to say this (and i dont get it) it didnt help.
I put the 2 files in the save games folder. I can see the savegame in game. I even see the screenshot of where i'm supposed to start but when the loading screen comes it takes like 15 seconds and the game crashes again. Just like before.
When i load it says something about till_DLCdungeon.esp missing, but i dont think that really mathers.
Any idea? :-/
I played around with settings, (de)activated some/all mods, nothing works.
Any idea? :-/
I'll check it, give me +-30 minutes. I have to check another problem at the moment.
The missing .esp shouldn't matter at all, it does not change anything in your current files; it just adds things (you can probably guess by the name). It could be that your installation is corrupted somehow :/
We'll see.
Could you attach your launcherlog?
C:\program files(x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\log\Launcher.log
Thanks.
We'll see.
Thanks.
Try to load this save.
If you can't load it try to uninstall and reinstall Enderal. Could be a problem within your installation.
blackadder2.rar
(3.53 MiB) Downloaded 95 times
