Hey everybody.
First of all love this game! It's really amazing.
Anyway, i'm level 16 right now and just got to chapter 2 in the mainquest.
It says i should be level 11 minimum and it's sending me to the northrealm.
Problem is i havent even seen different area's yet. like 'Salathin forest' which is lvl 14+
So if i continue the mainquest i will outlevel some area's? I'm a bit afraid to continue the mainquest because it's already sending me to the northrealm.
any tips?
continue mainquest or explore
Lumpensammler
Hi!
Really don't know what to advise you. Just do as you feel like doing. But I used to balance a bit. Some exploration/side quests and a little bit of the main quest. And it worked just fine.
Even if you go to the Northrealm, you will have the possibility to go back to previous regions.
Lumpensammler
Thanks for the first spoiler. Guess i'll continue the mainquest a little more
it's funny, when the mod came out i played untill lvl 10 and then i quit somehow.
I almost uninstalled nehrim, but last week i felt like giving it another try.
And since then i'm completely hooked. Just can't stop playing. Even think about it at work
btw, is it sure they are going to add crafting rank 2 in a future patch? Cause i can only craft iron gear...
Or will they even keep adding content in general?
Roland Deschain
Sterndeuter
- Danksagung erhalten: 1 Mal
btw, is it sure they are going to add crafting rank 2 in a future patch? Cause i can only craft iron gear...They are definitely adding more content in the future.
at the moment, a big addon that begins after the main story is developed that will add new quests and items.
There is no release date yet.
And they continuously fix reported bugs and add things such as new arena fights and bounty quests.
For all I know crafting will be expanded, too.
Lumpensammler
thats great news about the content!
One more question. where do the screenshots get saved? i took several but cant seem to find them anywhere.
And yes, i do have clicked the option in the launcher.
Casper
Erzmagistrat
- Hat sich bedankt: 4 Mal
- Danksagung erhalten: 6 Mal
Dj El Marriachi hat geschrieben: One more question. where do the screenshots get saved? i took several but cant seem to find them anywhere.they should be in your base nehrim directory (where you installed nehrim). for me that's "C:\Sureai\nehrim\". that's assuming you have activated screenshots in the ini files.
Experience may offer the best lessons, maybe even the most important ones; however, that doesn’t make her a good teacher… for only a poor teacher kills her students. –me
Fortune favors the foolish – because more often than not, the only thing separating bravery from stupidity is luck. -me as well
Lumpensammler
i had bAllowScreenShot=1 in the Ini. Screenshots weren't there though.
now i also changed iScreenShotIndex to 1. Not sure it will help cause i thought the above parameter should be enough.
strange.
strange.
Schicksalsbote
- Danksagung erhalten: 4 Mal
SSs only work if you have AA disabled. Check your Launcher, and eventually change to HDR, or use your Gafics Driver settings to enable AA.
Also, whenever the game crashes, the SS-index resets, and new SSs will overwrite existing ones, so be careful.
Casper
Erzmagistrat
himmelslicht hat geschrieben:Also, whenever the game crashes, the SS-index resets, and new SSs will overwrite existing ones, so be careful.i did notice that. then i noticed that i found that annoying too. hmm... i seem to find a lot of things annoying these days. there was a time i used to think i was such an easy going guy. *shrugs*
Lumpensammler
Still can't save screenshots. I took 15 now according to the launcher, but can find none. AA is disabled and, activate screenshots is on.
the game does seem to take a screenshot, but somehow doesnt save it.
Any idea's?
*edit, just when i wrote the above i thought of something. for some reason i didnt have acces to write to the folder where nehrim is located.
i granted permission to myself (?) and now it works
Any idea's?
