Hi
Does anyone know of a way to use Wrye Bashes bash patch with Nehrim.
Cannot add Nehrim as a master to the bash patch esp. Without being able to do that it crashes Nehrim.
Any suggestions?
Wrye Bash patch use on Nehrim?
7 Beiträge
“You have your way. I have my way. As for the right way, the correct way, and the only way, it does not exist.”
“I do not love the bright sword for it's sharpness, nor the arrow for it's swiftness, nor the warrior for his glory. I love only that which they defend” J.R.R. Tolkien quote
You should just replace all the characters of 'Oblivion.esm' in all "*.py" files in Nherim\Mopy folder by 'Nehrim.esm' using an editor.
(It's five : basher.py , bish.py , bolt.py , bosh.py , bush.py)
Now, if you double-click 'Wrye Bash Launcher.pyw', Wry Bash will work on only master 'Nehrim.esm' file.
Hi
Thank you Fujisan.
I will try that when I need to bash patch next time ( i.e. when I have too many mods installed )
Thank you Fujisan.
Hi.
Cheers.
Installed using self-installers, believe back at version 2.80.
Is it easy to update?
Cheers.
Yeah, I also checked operation of latest Wrye Bash, just now.
At the latest version v.291, since description of 'Nehrim.esm' is included in 'bosh.py', it works well by default.
I'd only uncompressed 'Wrye_Bash_291_--_Archive_Version-22368-291.7z' in the folder of Nherim.
Thank you Psymon, for telling new information.
I might have to point out one.
If you are using BOSS of the old version (1-5_Stable) for the mod's load order, there will be Oblivion.esm (perhaps dummy).
In that case ('Oblivion.esm' exist in Nehrim\Data folder), you need the above-mentioned replacement work.
Even if it removes the check of 'Oblivion.esm', the Bashed patch will make both 'Oblivion.esm' and 'Nehrim.esm' a master, if it is not carried out.
7 Beiträge
