bill2505 hat geschrieben:but it also needs obse.how do you install obse.the same as in original oblivionYou install obse like you would in oblivion.
Mod conversion requests
Antipathy hat geschrieben:psymon here disagrees http://forums.bethsoft.com/topic/124354 ... __19803925bill2505 hat geschrieben:can someone convert duke patrics archery mod http://tesalliance.org/forums/index.php ... t-archery/I got it working by just changing the master file from Oblivion.ESM to Nehrim.ESM using Wyre Bash.
bill2505 hat geschrieben:He can disagree all he wants that's fine because I didn't thoroughly test it!Antipathy hat geschrieben:psymon here disagrees http://forums.bethsoft.com/topic/124354 ... __19803925bill2505 hat geschrieben:can someone convert duke patrics archery mod http://tesalliance.org/forums/index.php ... t-archery/I got it working by just changing the master file from Oblivion.ESM to Nehrim.ESM using Wyre Bash.
Edit
What works:
moving while using you bow affects your shot and causes the arrow to denock.
enemies can be knocked down by arrows.
stealth damage
Using the bow degrades it faster like intended.
What Doesn't work
Trip Hazards
When you are surrounded by enemies or if one bumps into you your bow fumbles around. sometime causing you to drop arrows/bolts/quivers.
It supposed to scale you bow power when you activate the mod for your race etc, if it doesn't work right it over powers your bow like crazy.
Arrow Case
So yeah you probably need to re script it yourself if you want it to work right.
Grünschnabel
Could someone try to convert Summon Fairy Mod to Nehrim?
http://www.loverslab.com/topic/1566-sum ... companion/
I know it IS posibble since this video https://www.youtube.com/watch?v=3GdLRbLwm4w has it working on Nehrim, but I'm afraid no matter what I try, I can not get it working. I'm a total n00b but I've been trying to follow the tutorials, using tes4edit, but everytry has been unsuccessfull
I was hoping some very benevolent soul would help me out by dropping these beards into tirin abbey!
http://www.nexusmods.com/oblivion/mods/10870/?
I would adore my character bearded, and having a solid character design makes a game run for me!
