Darius' Treasure Hunt statue
6 Beiträge
Schicksalsknechter
- Hat sich bedankt: 71 Mal
- Danksagung erhalten: 133 Mal
I still haven't done the quest, so what I'm writing about is based on what I found on the wiki:
1) Do you have the quest active? Only then will the secret switch appear. ( may seem obvious, but it's better to ask:)
2) Check this one : http://nehrim.wikia.com/wiki/Giliad,_Crypt It says that the button is on the marked Knight Statue (check the map section in Gilida, Crypt) Can't you find the secret switch/lever/button there?
Good luck!
Good luck!
Schicksalsknechter
It is not the statue enclosed within the cage. You must explore further into other rooms to find the correct statue.
6 Beiträge
Mitglieder in diesem Forum: 0 Mitglieder und 11 Gäste
