In Safe Hands Trigger Problem? Quest doesnt continue :/
9 Beiträge
Hi!
If you don't get get help here, try the Support forum for reporting bugs.
In the meantime, I can help you only with giving the following clues:
1.use console commands to skip the quest stage (hope it helps, I've never used console commands for quests before):
http://nehrim.wikia.com/wiki/In_Safe_Ha ... st_Journal
or
2. Reload the quest from an earlier stage (it seemed to work with another person who got stuck in another quest)
Good luck!
or
Good luck!
Schicksalsknechter
- Hat sich bedankt: 71 Mal
- Danksagung erhalten: 133 Mal
I don't recall Callisto coming down any stairs. After you enter the Monastery and talk to Kim, you then go into Callisto's room and talk to him there.
QA Lead
- Schwarzer Wächter
- Hat sich bedankt: 23 Mal
- Danksagung erhalten: 45 Mal
That's one of the bugs related to the player and Kim having the same sex. At the moment I can just advise you to go into the main hall of the monastery, write "enableplayercontrols" into the console and manually talk to Kim.
9 Beiträge
Mitglieder in diesem Forum: 0 Mitglieder und 13 Gäste
