Any way to remove obsolete spells?
10 Beiträge
Just wondering if there is an easy way to remove spells that no longer get used when you reach the higher tiers. I seem to remember a mod of some type for Oblivion that could do that.
“You have your way. I have my way. As for the right way, the correct way, and the only way, it does not exist.”
“I do not love the bright sword for it's sharpness, nor the arrow for it's swiftness, nor the warrior for his glory. I love only that which they defend” J.R.R. Tolkien quote
QA Lead
- Schwarzer Wächter
- Hat sich bedankt: 23 Mal
- Danksagung erhalten: 45 Mal
Wrye Bash does that:
http://wryebash.netai.net/
You just need to copy your Oblivion.esm file into the Nehrim\Data directory (or create an empty file named Oblivion.esm), because otherwise Wrye Bash won't start.
arvisrend hat geschrieben:Wrye Bash does that:WyreBash itself isn't very user friendly though. The install instructions look like something out of a programming course. I can't wrap my old brain around the instructions.
arvisrend hat geschrieben:Wrye Bash does that:Wrye Bash on and working, cheers for all the input folks.
Copying Oblivion.esm causes Nehrim to crash on my system, created new file instead.
WyreBash itself isn't very user friendly though. The install instructions look like something out of a programming course. I can't wrap my old brain around the instructions.Download the self installers from Nexus (Wrye-python and Wrye- bash). Do not do what I did first and install stupidly to Oblivion directory ( had to uninstall and in so doing using Revo uninstaller removed some Oblivion files, had to reinstall Oblivion.)
Update to post above. Today tried wrye bash and would not start. Re-installed and nada. Found I had to copy oblivion esm to have it start today. Go figure.
I was able to get the below Oblivion Spell Delete mod to work fine in Nehrim yesterday..after using Tes4Edit to change it from the Oblivion ESM to Nehrim.
http://www.tesnexus.com/downloads/file.php?id=23069
I used the SPELL DELETE ONLY portion of the mod. It seems to work fine using the default key but I was unable to customize a keyboard key for it.
Hi.
Tried both. Sticking with wrye bash, it has some extra perks. You do have to delete spells out of game, but thats easy enough. Can view all my screenshots in wrye bash and It looks to be an easy operation to import a face from a different character (savegame) plus other imports.
10 Beiträge
