Hello. I was just wondering if there is any way to make Enderal utilize more of my system resources for a smoother experience. My cpu usage never goes above 20%, and my gpu above 40%. I get about 40-70 fps most of the time but I would like a more stable experience if possible.
Specs:
Intel Core i9 9900k @ 4.7 ghz
Gtx 1080ti
32gb ram @ 3200 mhz
144hs monitor
Game is on a 7200 rpm WD Black HDD
Any help is appreciated. Thanks.
Utilization
3 Beiträge
Stefanie
- Hat sich bedankt: 733 Mal
Skyrim has an older engine, which can only use newer hardware to a limited extent
The Skyrim engine likes to cause problems with more than 60 fps, at least 80 fps there are problems with Havok.
This means that players, NPC´s or objects sometimes slip through static models, which can also lead to game errors.
For this ENBoost has a brake at approx. 60 fps to reduce such problems.
You can also display the real fps ingame via this program with [*] on the numeric-keypad.
(Other programs possibly don't show you true Ingame-FPS)
urst
- Hat sich bedankt: 671 Mal
02.03.2019 00:16GreyBear hat geschrieben: Hello. I was just wondering if there is any way to make Enderal utilize more of my system resources for a smoother experience. My cpu usage never goes above 20%, and my gpu above 40%. I get about 40-70 fps most of the time but I would like a more stable experience if possible.(moved your thread; just quoting to make sure you don't think we deleted it,
Specs:
Gtx 1080ti
32gb ram @ 3200 mhz
144hs monitor
Stefanie pretty much said it all )
3 Beiträge
