Music files are bugged
11 Beiträge Seite 1 von 2
Taters
Lumpensammler
Lumpensammler
Hello!
so I encountered the bug where the silence track would get stuck on repeat which I fixed using one of the removemusic commands. Afterwards my combat now got stuck on repeat and using the same command I fixed it so that when im in exterior zones the normal music plays.
However the issue has changed again, now no dungeon music plays, nor any combat music only the exterior soundtracks play. If I attack an enemy the normal music plays, but if I reload to a previous save, one where my character isn't in combat the combat music now gets stuck on repeat.
Is there any way to get all my music working properly and not stuck in repeat? Thanks
urst
Schöpfer
Schöpfer
Hat sich bedankt: 694 Mal
Danksagung erhalten: 635 Mal
welcome to the forum :)
did "no music at all" and "only combat music on repeat" occur directly one after the other
or was there some time in between?
the latter can usually be solved by reloading.
(it happens when you discover a location while in a fight)
maybe the "game got confused" when you console-commanded both, and that's why it's stuck now on reloading :?:
(no idea)
does it happen with all older saves?
and could you upload a savegame please?
found in ...\Documents\My Games\Skyrim\Saves, we'll need the skse and the ess of a manual (no quick- or auto-) save
pack them to a rar or zip archive and attach them to a post here :)
Taters
Lumpensammler
Lumpensammler
https://yadi.sk/d/-qp7h34a3ZyRsT
Thanks for the fast reply,
Yes they both happened one after the other. Whenever I load the game the battle music always comes on, and then once I do the removemusic command, no dungeon or battle music will play.
urst
Schöpfer
Schöpfer
uhm, thanks, but the ess would be pretty good to have ;)
Taters
Lumpensammler
Lumpensammler
urst
Schöpfer
Schöpfer
:lol:
ok, combat music all the way.
(didn't bother trying to cheat)
there seem to be some other issues though.
- what mods are you usually running?
the enemies are behaving oddly and I assume skse_tkplugin.log belongs to tk dodge?
- what other cheats did you use?
(except carryweight and removemusic)
edit
what ID are you using in with that command?
Taters
Lumpensammler
Lumpensammler
Thanks for checking my files, I'm not running any other mods at all, in enderal or skyrim, I installed both afresh just to play enderal. The only cheats I've used are various removemusic commands. I think the problem arose during the quest the voice in the water if that helps.
edit: the command i used is removemusic 000951f7
Taters
Lumpensammler
Lumpensammler
I've just gone through my previous saves and discovered that the music stops playing completely when I go near the location Dragon aerie. Once the dragon becomes aggressive the combat music doesn't start nor does any other track.
Music starts occuring after using the command removemusic _00e_silencelongtransitionhighpriority but combat and dungeon music does not start playing when its meant to.
urst
Schöpfer
Schöpfer
hm, I played again (with your save),
and this time I tried the removemusic command.
that brought back the usual exploring track.
getting in fights seemed to either have zero effect on the music (which sometimes does happen with shorter fights),
or complete silence (apparently)
reloading didn't change to combat music though :/
if that problem first appeared with the "voice in the water" - quest,
did you check saves from before that point?
(yes, your posts suggested it, just want to make sure :) )
urst
Schöpfer
Schöpfer
hm.
could you load a save from before getting in the fight with the dragon,
not fight it, and see how the music behaves subsequently :?:
