Hello SureAI i have been trying to get your game to work for the past two days and I finally decided to come to y'all for help ok so. The thing is I am stuck the launcher says my version is up to date but I know it is not but it says it is can you help me please. If you need anything just ask thank you. In short it is not detecting the latest update but it is connected to your servers.
PS this was meant to be in the enderal forum sorry for that new to this site don't know where to go just saw the word skyrim and thought to go there.
Enderal Installation / Update problem
Krieger
Kermit 61
- Hat sich bedankt: 405 Mal
Welcome to the forum!
Your topic is now in the right place .
Which version is displayed in the launcher (the current patch is 1.2.0.7, Launcher A63)?
You can try to start the update process again:
-Close the Enderal launcher.
-Run a text editor like Notepad++.
-Open up your conf.sur with the text editor.
-The file is located in your game directory ...\Skyrim\EnderalLauncher\system\config\conf.sur.
(C:\program files(x86)\Steam\Steamapps\common\Skyrim\EnderalLauncher\system\config\conf.sur being the default path of your installation if Skyrim was installed via Steam).
-Edit the line sCurrentVersion=x.x.x.x to sCurrentVersion=1.1.0.0 and save the file.
-Run the launcher as admin and install the patches again.
Krieger
Hey thank you for replying i have already done all that i have been looking for solutions all over the web for the past two days and i think i found something i found a old post that was posted on the sureAI website forums where one of the people on it gave the person links to the updates to download them manually. I will say something if it does not work thank you.
March and Claim
Krieger
Hey back again it did not work and one thing i forgot to mention was that when i try to launch the game from the launcher it says "enderal needs an update first" but i am back to square one the launcher does not want to detect the update.
PS: the launcher is version 1.1.0.0 thank you.
March and Claim
Krieger
[[ Starting Launcher ]]
Log started at 2017/07/24 22:21:22
If you encounter any issues with the Enderal Launcher, this file might be helpful for fixing it.
Please use our Bugtracker at http://tracker.sureai.net to report this problem.
Release ID: A63
Release version: Skyrim Classic
Build date: 7/24/2017 10:21:14 PM
Creation date: 7/24/2017 10:21:05 PM
App start location: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\
App game folder: Skyrim\
Operating System: Microsoft Windows NT 6.2.9200.0
NET Versions: 4.6 or later
Language: EN
Build version: 1.1.0.0
Game version: 1.1.0.0
Internet connection: True
Installation status: False
Steam status: True
OneTweak status: True
Directory search status: True
Master found: True
SKSE found: True
Last external startup path: 0
Last external executable: 0
Backup path Enderal: path
Backup path Skyrim: path
> Start logging:
<22:21:22> Conf - Initialize conf file
<22:21:22> Conf - Unpack Readme
<22:21:22> Conf - Initialize conf file [DONE]
<22:21:22> Conf - Save conf file
<22:21:22> Conf - Save conf file [DONE]
<22:21:22> Conf - Checking Environment
<22:21:22> Conf - Checking Environment [DONE]
<22:21:22> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<22:21:22> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<22:21:22> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<22:21:22> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<22:21:22> Main - Initialize Unpatcher
<22:21:22> Main - Unpatcher [DONE]
<22:21:22> Main - Create environment
<22:21:22> Main - Create environment [DONE]
<22:21:22> Main - Initialize network
<22:21:22> Net - Connection enabled in settings
<22:21:23> Net - System is connected to network
<22:21:23> Net - Try to establish server connection thread
<22:21:23> Net - Thread STARTED
<22:21:23> Main - Initialize network [DONE]
<22:21:23> Net - Choose server
<22:21:23> Net - Connect to [DL3]
<22:21:23> Net - Server connection attempt #1
<22:21:23> Main - Initialize intervall
<22:21:23> Main - Initialize intervall [DONE]
<22:21:23> Main - Initialize PanBase
<22:21:23> Main - Initialize PanBase [DONE]
<22:21:23> Main - Initialize CPanel
<22:21:23> Cp - Cp Initialisation
<22:21:23> Main - Initialize CPanel [DONE]
<22:21:23> Cp - No connection to server established yet, try again in 5 seconds...
<22:21:23> Cp - Check Cp file
<22:21:23> Cp - Abort: Cp does not exist
<22:21:23> Conf - Hardware Scan:
<22:21:23> Conf - CPU: AMD A8-4500M APU with Radeon(tm) HD Graphics , Speed: 1900, Cores: 4
<22:21:23> Conf - GPU: AMD Radeon HD 7640G, Memory: 0 GB
<22:21:23> Conf - RAM: 7 GB
<22:21:23> Conf - DISC: 304605 MB
<22:21:23> Net - Connection port: 80
<22:21:23> Net - Connection default port: True
<22:21:23> Net - Connection proxy bypassed: True
<22:21:23> Net - Connection OK
<22:21:23> Net - Start listing available versions on [DL3]
<22:21:26> SetUp - fillRecommendedSysLabels
<22:21:28> Cp - Retry thread started attempt #1
<22:21:28> Cp - Try download Cp file
<22:21:28> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\config\ top level
<22:21:28> SetUp - Choose installationfile
<22:21:28> Cp - Downloaded Cp file
<22:21:28> Cp - Check Cp file
<22:21:28> Cp - Cp file seems valid, reading...
<22:21:28> Cp - Abort: Downloading pics needed
<22:21:28> Cp - Downloaded pic: 1
<22:21:28> Cp - All pics downloaded total count 1
<22:21:28> Cp - Abort: Check existing Pics
<22:21:28> Cp - Start Cp pic checker
<22:21:28> Cp - All pics found
<22:21:53> SetUp - Choose backup
<22:21:58> SetUp - Ready for installation
<22:22:00> SetUp - Started Create Skyrim backup command
<22:22:00> SetUp - Started, moving files:131 At rate:0.7633588
<22:22:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\ top level
<22:22:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Interface\ top level
<22:22:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\scripts\ top level
<22:22:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\scripts\Source\ top level
<22:22:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Strings\ top level
<22:22:00> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\data\Video\ top level
<22:22:04> SetUp - Started Install Enderal command
<22:22:04> SetUp - Source gz/zip found with size: 8427964531
<22:22:04> SetUp - Try start archive extraction
<22:22:04> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\Data/ top level
<22:22:04> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<22:22:04> SetUp - Started, installing files:204 At rate:0.4901961
<22:32:43> Net - System is connected to network
<22:32:43> Net - Try to establish server connection thread
<22:32:43> Net - Thread STARTED
<22:32:43> Net - Choose server
<22:32:43> Net - Connect to [DL2]
<22:32:43> Net - Server connection attempt #2
<22:32:43> Net - Connection port: 80
<22:32:43> Net - Connection default port: True
<22:32:43> Net - Connection proxy bypassed: True
<22:32:44> Net - Connection OK
<22:32:44> Net - Start listing available versions on [DL2]
<22:32:44> SetUp - Enderal Installation done
<22:32:59> Conf - Save conf file
<22:32:59> Conf - Save conf file [DONE]
<22:32:59> Exit(A)
Log started at 2017/07/24 22:33:05
Release ID: A63
Language: EN
Installation status: True
Steam status: True
Master found: False
SKSE found: True
Backup path Skyrim: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\skyrim\
> Start logging:
<22:33:05> Conf - Initialize conf file
<22:33:05> Conf - Initialize conf file [DONE]
<22:33:05> Conf - Save conf file
<22:33:05> Conf - Save conf file [DONE]
<22:33:05> Conf - Checking Environment
<22:33:05> Conf - Checking Environment [DONE]
<22:33:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\system\ recursive
<22:33:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\update\ recursive
<22:33:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\EnderalLauncher\backup\ top level
<22:33:05> Func - RWP: C:\Program Files (x86)\Steam\steamapps\common\Skyrim\ top level
<22:33:05> Main - Initialize Unpatcher
<22:33:05> Unpa - Start cleanup
<22:33:05> Main - Unpatcher [DONE]
<22:33:05> Main - Create environment
<22:33:06> Main - Create environment [DONE]
<22:33:06> Main - Initialize network
<22:33:06> Net - Connection enabled in settings
<22:33:06> Net - System is connected to network
<22:33:06> Net - Try to establish server connection thread
<22:33:06> Net - Thread STARTED
<22:33:06> Main - Initialize network [DONE]
<22:33:06> Main - Initialize intervall
<22:33:06> Main - Initialize intervall [DONE]
<22:33:06> Net - Choose server
<22:33:06> Main - Initialize PanBase
<22:33:06> Net - Connect to [DL4]
<22:33:06> Net - Server connection attempt #1
<22:33:06> Main - Initialize PanBase [DONE]
<22:33:06> Main - Initialize CPanel
<22:33:06> Cp - Cp Initialisation
<22:33:06> Main - Initialize CPanel [DONE]
<22:33:06> Cp - No connection to server established yet, try again in 5 seconds...
<22:33:06> Cp - Check Cp file
<22:33:06> Cp - Read old Cp file
<22:33:06> Cp - Abort: Check existing Pics
<22:33:06> Cp - Start Cp pic checker
<22:33:06> Cp - All pics found
<22:33:06> Net - Connection port: 80
<22:33:06> Net - Connection default port: True
<22:33:06> Net - Connection proxy bypassed: True
<22:33:06> Conf - Hardware Scan:
<22:33:06> Conf - CPU: AMD A8-4500M APU with Radeon(tm) HD Graphics , Speed: 1900, Cores: 4
<22:33:06> Conf - GPU: AMD Radeon HD 7640G, Memory: 0 GB
<22:33:06> Conf - RAM: 7 GB
<22:33:06> Conf - DISC: 296248 MB
<22:33:06> Net - Connection OK
<22:33:06> Net - Start listing available versions on [DL4]
<22:33:11> Cp - Retry thread started attempt #1
<22:33:11> Cp - Try to compare server with local file
<22:33:11> Cp - Connection port: 80
<22:33:11> Cp - Connection default port: True
<22:33:11> Cp - Connection proxy bypassed: True
<22:33:11> Cp - Connection OK
<22:33:11> Cp - 12/2/2016 4:38:16 AM 7/24/2017 10:21:28 PM
<22:33:11> Cp - Up-to-date
<22:33:11> Cp - Check Cp file
<22:33:11> Cp - Read old Cp file
<22:33:11> Cp - Abort: Check existing Pics
<22:33:11> Cp - Start Cp pic checker
<22:33:11> Cp - All pics found
<22:33:18> Conf - Save conf file
<22:33:18> Conf - Save conf file [DONE]
<22:33:18> Exit(A)
I thought maybe you would need this your welcome i did notice it said masters found false what does that mean?
Release ID: A63
Language: EN
Steam status: True
Master found: True
SKSE found: True
> Start logging:
<22:32:59> Exit(A)
Release ID: A63
Language: EN
Steam status: True
Master found: False
SKSE found: True
> Start logging:
<22:33:18> Exit(A)
March and Claim
Krieger
Ok i got it to come up the game that is but the update still wont come up it wont detect it. I got the game to come up by following something someone else did that is copying the skyrim.esm file to the data folder but now when it comes up i try to hit new game the text that says explore enderal does not come up for some reason and even if i hit yes anyway it just leaves me on the main menu screen does not go anywhere stays there. And how i knew the new game option says explore enderal because i saw people make lets plays of the game and i watched the beginning thats how. But i think i know why it is doing that i am using the skyrim.esm i think i need a different esm like example Enderal.esm or something i think the esm for skyrim is made for skyrim only thats why i can't see the new text.
March and Claim
Kermit 61
No. The skyrim.esm is correct. Enderal needs it.
Is there any write protection on your Skyrim / Enderal directory? Try to disable this write protection and/or restart your PC. The Enderal launcher needs to be run as admin.
Krieger
There was write protection can that really do this wow i will restart now be right back thank you.
March and Claim
Krieger
Update: just got through trying to get rid of the write protection all attempts have failed so i made another partition out of my local disk and am moving my steam directory to it will keep y'all informed thank you.
March and Claim
