Hi!
There are huge chunks of missing terrain objects at the mountain pass region north of Ark. I noticed this quite early in the initial release and in the latest version they are still missing, so I thought I report it.
Screenshots:
http://images.akamai.steamusercontent.c ... 1853D6DCC/
Second one near the mammoths:
http://images.akamai.steamusercontent.c ... C2B4377BA/
Missing terrain static objects
Gauner
Gauner
stuemper
Enderal Team
- Schwarzer Wächter
- Hat sich bedankt: 127 Mal
As I said it is supposed to be fixed since 1.1.3.5. I fixed it myself, and just checked back and it seems that everything is Ok in the CK.
So, no idea..
Is anyone else still encountering this bug?
So, no idea..
I too am missing that bridge-like structure. I can walk over it, but can not see it.
I have 1.1.5.7 A54
This is what I see (also note the rocks in the upper left corner - those are not correct either)
https://www.dropbox.com/s/mntpmui61mvhk ... 0.png?dl=0
EDIT:
NOW it is fixed ????
After taking the above picture, and continuing the game - that bridge (and yes I can see it is a stone bridge) and the surrounding area are fine now.
I did not change anything, did not update anything. Maybe just being in the cell when the game continued fixed this issue.
Edit #2:
After playing a little more, I swung back around to this bridge, and it was gone again. For some reason it is not loading properly. Not just the bridge, there is a large section of the mountain, behind the bridge that is missing as well. But if I save the game at that location, exit Enderal, then restart the game the area looks fine.
I have 1.1.5.7 A54
EDIT:
Edit #2:
Gauner
Also found missing objects in the are of Kaltyzar (Dark Valley)
The ravine next to it completely missing water, so you are falling through it:
http://images.akamai.steamusercontent.c ... 9506167B0/
Pathway leading up to the fort completely missing:
http://images.akamai.steamusercontent.c ... 4BAD9895C/
Gauner
Tilliboy hat geschrieben:Could you check if you have mods active in your launcher?Yes a few, but nothing that affects static objects or textures
stuemper
Enderal Team
- Schwarzer Wächter
bobbysolace hat geschrieben: Yes a few, but nothing that affects static objects or texturesThey could interfere, doesn't matter if they shouldn't!
Could you please check the areas without mods and please tell me which mods are in usage. Thanks!
Mitglieder in diesem Forum: 0 Mitglieder und 10 Gäste
