So when I press "Launch Enderal" in the Launcher, it brings up that black window with all the coding for a split second (like normal), and then nothing happens for a few seconds. Then, a white window pops up that says "Application Load Error P:0000065432"
I was just playing last night with absolutely zero problems, and there have been no updates to anything. No Steam update, no Enderal update, no Windows update, nothing. It has just decided to stop. Help would be lovely!
Application Load Error? [solved]
5 Beiträge
Enderal Team - Weltenwandeler
- Hat sich bedankt: 51 Mal
- Danksagung erhalten: 138 Mal
Is your Steam activated (you do not need to be online, it just needs to be running)?
Usually this application error only appears if you try to directly open the game without Steam.
Did you try to log out of Steam and log back in? Sometimes this problem happens if you are constantly logged in.
Third sort of fix - try to run the Enderal Launcher as administrator, this also seems to fix it for some people.
Best Regards,
Caleb.
Best Regards,
Caleb.
5 Beiträge
