No radial blur mod ?
5 Beiträge
stuemper
Enderal Team
- Schwarzer Wächter
- Hat sich bedankt: 127 Mal
Documents/MyGames/SkyrimPrefs.ini:
Code: Alles auswählen
deactivates the depth of field.bDoDepthOfField=0
Schurke
- Hat sich bedankt: 2 Mal
- Danksagung erhalten: 5 Mal
Tilliboy hat geschrieben:Documents/MyGames/SkyrimPrefs.ini:Depth of Field and Radial Blur are two separate things in Skyrim. I think they want to get rid of the blur around the edges of the screen during combat. There is a setting in the ini, iRadialBlurLevel, but I think it has been widely understood that setting it to 0 does not disable the effect.Code: Alles auswählendeactivates the depth of field.bDoDepthOfField=0
From the STEP Wiki.
iRadialBlurLevel
This setting does not appear in game-generated INIs--only ones created by the Skyrim Launcher via the preset files, where Low and Medium is 0, High is 1, and Ultra is 2. It has been empirically verified that changing this setting in SkyrimPrefs.ini has no effect in game, but instead must be changed inside Skyrim.ini, otherwise the default value shall be used (which is 0). However, changing the setting in Skyrim.ini may induce CTD whenever radial blur is applied!
5 Beiträge
