Strange things happen in arktwend
Moderator:Moderatoren
6 Beiträge Seite 1 von 1
FreezeProblem
Krieger
Krieger
Danksagung erhalten: 1 Mal
First thing is I am getting "Menu error: Bad Memory Pointer" error very often when picking up items from ground (when picking gold near "sun circle", when picking gold somewhere else, when picked gold nugget in the boat, when taken boots of blinding speed - it is irritating)
This is a bit strange since I never got it in morrowind (and I played it very long and only error I have seen is "missing arrow bone" when bound bow disappear during shot and that was exacly same morrowind setup on this very the same machine).
But it is not all... few minutes ago alchemy just went crazy! When clicking on ingedient to get it out of slot there appeared goblin shield (right in the ingredient slot) and it got unequipped just like when enchanting... I clicked it out of slot (it was in 2nd slot) and then I clicked out first ingredient and game CTD. It may be somehow be tied up to enchanting npc to which I have talked and then opened and closed enchant window)
Is there any fix or explanation? Can my saves be corrupted now?
Also I have version in mind that it is somehow because of thread loading + 500mb/s reading SSD but it would be hard to confirm.
PS how things installed:
morrowind with expansions + MCP 2.0 + MGE XE 0.98 + arktwend german 2.0 + patch 2.015 + arktwend english 3.1 + patch for it (contains textures only) + my plugin that fixes 2 broken things (StormwendRauberControl script and Lorum-Rune spell).
SakalCT
Lumpensammler
Lumpensammler
Are you sure that you have installed the lastest patch for Bloodmoon? I should be 1.6.1820. It is displayed on menu screen in the left down corner.
I use Steam installation of Morrowind (so the last patch is included automatically) + german 2.0.0. Arktwend installer + English 3.1 translation + english patch + TAO 0.14 + MGE and it works fine for me. I didn´t apply that german patch ´cause I think it has nothing to do with English version.
FreezeProblem
Krieger
Krieger
Yep it is 1.6.1820.
As I googled "bad memory pointer" is common morrowind issue. The rate at which I get it in arktwend is high probably because of alot items placed on ground (in original mw I did not pick up that much).
The glitch with goblin buckler can be reproduced in original morrowind with any shield without body part (but there was no such glitchy shield so I made one in TESCS for this test).
So this both not an Arktwend fails actually.
BTW did you notice that lorum rune does NOT work? I was really surprised by this that it was yet broken in such late version. Hope I wont be surprised again by something but I will save often in different slots.
Now I am making fix for all errors I can find and also mod which mods leveled creatures to spawn stronger variants for higher levels. This would be 2 different .esp
SakalCT
Lumpensammler
Lumpensammler
FreezeProblem hat geschrieben:
No, I did not. In fact only runes I use are the Ark (or Arkt?) runes. There is another glitch I found. You can't have equipped cloak and right glove in the same time. Equipping one automatically removes the other. This is glitch because I don't see any reason why couldn't you wear both.
FreezeProblem
Krieger
Krieger
I will look on it. How this cloak is called in game? Is it that "cloak" which attached to hood?
I already fixed few things including few scripts one of which broken levitation and teleport disabling. May be some day I will fix all bugs.
SakalCT
Lumpensammler
Lumpensammler
I believe it's called "hooded cloak". There are several versions of different colors but non of them works. And in fact it doesn't work with LEFT glove.
Anyway there's another and more cardinal glitch I found:
After I returned from the "looking for Dwarf prince" quest (what a challenging quest! :-) ) two Kanzler's mages escorted me to him and then I was sent to jail. I had equipped "Patron Left Glove" (sadly I have no idea where I found this) and in the jail I was unable to move even after my liberation. I was just permanently stuck to the ground. I checked it several times. The Glove has several powers like all resistances +10, shield +10 and drain strength -5. Luckily I saved my game just before being captured and second time I just unequipped this glove before I approached the Mages and everything worked perfectly.
