crash to desktop
Moderator:Moderatoren
21 Beiträge Seite 1 von 3
Tarif
Grünschnabel
Grünschnabel
Hat sich bedankt: 1 Mal
When I play the game it randomly crashes to desktop with no message at all. This happens at random intervals. I already got a clean version of skyrim and then installed it but it keeps doing it. For the rest the game is playable its just you never now when it will shut down so you need to auto save every 5 minutes.
Also thanks for the hard work I really like what I have seen so far and am interested in the story.
Vandriam
Gauner
Gauner
Danksagung erhalten: 2 Mal
Hi there, i also had ctd quite oftenly (at least 1 or more per hour), i digged a bit german forums and i found these :
http://forum.sureai.net/viewtopic.php?f=201&t=8259
http://www.elderscrollsportal.de/themen ... st-1047694
http://www.elderscrollsportal.de/themen ... son.52141/
to make it short, all you have to do is :
- change UseOSAllocators=0 to UseOSAllocators=1 in Skyrim\Data\SKSE\Plugins\CrashFixPlugin.ini
- download an extract d3dx9_42.dll from this this mod http://www.nexusmods.com/skyrim/mods/75795/? to your skyrim folder (where TESV.exe is).
- enjoy !
Now i have much longer gaming sessions, i still have ctd, but for others reasons, usually while loading screens, not in the wilderness, also, loading screens are a bit faster because basically with previous operation you replaced skyrim default memory allocator by the windows one which is more reliable.
Tarif
Grünschnabel
Grünschnabel
Thanks for the reply it works perfectly now no random crashes !!!!
kronicdecay
Lumpensammler
Lumpensammler
Hat sich bedankt: 2 Mal
Editing the .ini file and adding the .dll file did help. I'm still occasionally getting an in game CTD but not near as often as I was. So thank you.
zaboleqqq
Lumpensammler
Lumpensammler
Danksagung erhalten: 1 Mal
I have several CTD but they only occurs when I try to change location . For example I've entered Abandoned bee farm (small hause) and when I try to leave it (so game need to load new aresa) I will get CTD. I had it several times now and I'm really worried because the first thing which I need to do every time when I enter new dungeon/mine/tomb/etc is to check if I can leave it. I'm on win10.
I've never got CTD during normal exploration outside dungeone/mines/house/tombs. CTD only occurs during changing location from one to another.
Any tips? I'm using this DLL file and I've did changes in skyrim ini and crashplugin. It does not matter for me because It is lik 99% that game will crash if I will exit one of those locations (I was able once to exit Keldorn Tomb - luck?).
Vandriam
Gauner
Gauner
Hi, if this little hotfix doesn't help you, you can try following things :
- use enderal vanilla version, no mod loaded from launcher, no enb, etc
- reinstall or repair from following exe : Skyrim\VCRedist\vcredist_x86.exe Skyrim\DotNetFX\dotnetfx35setup.exe
- refresh your directx install from official MS installer here : https://www.microsoft.com/en-us/Downloa ... aspx?id=35
- refresh your drivers (especially gpu ones)
if it doesn't change anything, i'll need more informations from crashes to help you, so, enable skyrim engine to generate logs, edit Skyrim.ini from launcher (Settings, others tabs) and change Papyrus section to :
[Papyrus]
bEnableLogging=1
bEnableTrace=1
bLoadDebugInformation = 1
Save and play until next crash, it will create you a Logs folder in skyrim directory, send me all logs file inside. you can use pastebin.com to make it easier and post links here.
zaboleqqq
Lumpensammler
Lumpensammler
I don't have any mods installed. Enderal is the only one :). I do not use any enb other than ENB from Enderal (is there any way to disable it?)
When it comes to enabling logging, I've did it but after game crashed during exiting cells (Keldron family Crypt), nothing was logged. If You want I can send You my saves somehow. But I have a lot crushdump from SKSE folder from my documents...
C:\Users\zabol\Documents\My Games\Skyrim\SKSE\Crashdumps
Zuletzt geändert von zaboleqqq am 22.08.2016 19:47, insgesamt 1-mal geändert.
Vandriam
Gauner
Gauner
Ok, go on i'll check if they run fine for me, i have already seen some bad quest trigger create a corrupt game, in this case try to get a save before your first crash or create a new game.
Vandriam
Gauner
Gauner
theses crashdump are raw memory dumps meant for debugger, that's not human readable, only devs can do something with it. that's why i wanted to have papyrus logs.
zaboleqqq
Lumpensammler
Lumpensammler
I turned out that I have papyrus logs, It just took some time to create them. Those 3 links are 2 logs file and my game saves:
https://drive.google.com/open?id=0B_CnJ ... 1YxV0pzalU
https://drive.google.com/open?id=0B_CnJ ... DFUNXNjbzQ
https://drive.google.com/open?id=0B_CnJ ... nFCeWZhbmc
Begginig looks like this:
[08/22/2016 - 06:39:15PM] Papyrus log opened (PC)
[08/22/2016 - 06:39:15PM] Function GetEffectMagnitudes in the empty state on type Ingredient does not exist. Function will not be flagged as callable from tasklets.
[08/22/2016 - 06:39:15PM] Update budget: 1.200000ms (Extra tasklet budget: 1.200000ms, Load screen budget: 500.000000ms)
[08/22/2016 - 06:39:15PM] Memory page: 128 (min) 512 (max) 76800 (max total)
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_SelfDamageInstant", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_LiliathStartsPlaying", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_MossCraterAltarScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_FlyingMoundLandTriggerScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_FlyingMount_TakeoffScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_NQ05GeheimkellerTrigScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_CQJ02_SC02_MusicControlSC", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_UndercityTrainigChestScript", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_Testsword_Shader", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_AnthaldriumSCN", missing file?
[08/22/2016 - 06:39:18PM] Cannot open store for class "_00E_ActivateLinkedChain", missing file?
[08/22/2016 - 06:39:19PM] error: Unable to bind script _EPGlobal to Levelsystem (00010AA2) because their base types do not match
[08/22/2016 - 06:39:19PM] Cannot open store for class "QF_StartQuest_000871A5", missing file?
And end looks like this
[08/22/2016 - 06:39:27PM] error: Property MS02 on script MineOreScript attached to (00053F37) cannot be bound because (00040A5E) is not the right type
[08/22/2016 - 06:39:27PM] warning: Property Myrad on script TIF__0100D6B7 attached to topic info 000753C6 on <NULL quest> cannot be initialized because the script no longer contains that property
[08/22/2016 - 06:39:48PM] Loading game...
[08/22/2016 - 06:39:48PM] error: Native static function MoveGroup could find no matching static function on linked type utility. Function will not be bound.
[08/22/2016 - 06:39:48PM] VM is thawing...
[08/22/2016 - 06:39:49PM] InitWidgetLoader()
[08/22/2016 - 06:39:49PM] InitWidgetLoader(): load failed
[08/22/2016 - 06:39:50PM] InitWidgetLoader(): load failed
[08/22/2016 - 06:39:54PM] error: Cannot call HasForm() on a None object, aborting function call
stack:
[ (00016C7B)]._00E_ChestAndDoorLockScript.OnActivate() - "_00E_ChestAndDoorLockScript.psc" Line 40
[08/22/2016 - 06:39:54PM] warning: Assigning None to a non-object variable named "::temp14"
stack:
[08/22/2016 - 06:41:14PM] VM is freezing...
[08/22/2016 - 06:41:14PM] VM is frozen
Mitglieder in diesem Forum: 0 Mitglieder und 13 Gäste
