Hey, just recently picked up Enderal and installed it into a clean skyrim. Just installed CBBE into it as well and I can't seem to find any of the Enderal armor to batch build into my CBBE preset. Am I doing something wrong or is it not possible to batch build it?
I do believe this mod already has CBBE because I read the readme and found this: "Naked Bodies by Caliente" although they are not naked, women of Enderal are quite good looking. http://imgur.com/kMQOkuM
Also its recommended to install mods that are said to be working with Enderal, unless you want glitches and bugs.
Hey TheCloudDistrict you can use this Guide, with this you have CBBE, HDT and Skimpy Armor
Here are the Mods for CBBE, HDT, HDT Bounce and Jiggles with remoddeld skimpy Armor
Install Order:
01 Realistic Ragdolls and Force
http://www.nexusmods.com/skyrim/mods/601/?
02 Bounce and Jiggles CBBE CT77 HDT Only Body (found under Updates) http://www.nexusmods.com/skyrim/mods/59416/?
03: Bodyslide and Outfit Studio
www.nexusmods.com/skyrim/mods/49015/?
04: Caliente's Beautiful Bodies Edition
http://www.nexusmods.com/skyrim/mods/2666/?
05: Fair Skin Complexion for CBBE 8.0
http://www.nexusmods.com/skyrim/mods/51602/?
06: Fair Skin Complexion Extra Options (zu finden unter Optional Files)
07: RaceMenu
www.nexusmods.com/skyrim/mods/29624/?
08: HDT Physics Extensions
http://www.nexusmods.com/skyrim/mods/53996/?
09: Bounce and Jiggles 7.0 - HDT Havok Collisions Object (found under Optional Files, IMPORTENT: Deslect Havok Breast Physik Dawnguard.esp and Havok Breast Physik Dragonborn.esp)
10: Bounce and Jiggles 7.6 BM2 Exaggerated TBBP_Belly (found under Main Files)
11: XP32 Maximum Skeleton Extended for Enderal (found under Miscellaneous)
www.nexusmods.com/skyrim/mods/68000/?
12: FNIS Behavior
http://www.nexusmods.com/skyrim/mods/11811/?
13: FNIS Patch for Enderal
http://www.nexusmods.com/skyrim/mods/76979/?
14: Remodeled Armor for CBBE Bodyslide TBBP HDT
www.nexusmods.com/skyrim/mods/25259/?
If you have installed these Mods, then start TES5Edit, deslect all Mods and select Remodeld Armor - Vanilla Replacer.esp
Step 1: Click on Remodeld Armor - Vanilla Replacer.esp
Step 2: Click on ArmorAddon and select all
Step 3: Make a right click and chose Apply Script (you must have Automation Tools for Tes5Edit installed)
Step 4: Chose the Script AT - Quickchange
Step 5: As function chose ElementAssign
Step 6: In the Field Path write MODL
Step 7: In the Field Value write [RACE:00033899] and click ok
Step 8: Repeat Step 1 to 6, and write now in the Field Value [RACE:00033898] and Click Ok
Now you can close Tes5Edit
(If you use Mod Organizer double click on Overwrite and delete all files in there)
Then run FNIS and checkmark the first two checkboxes and click ok
Close FNIS.
(If you use Mod Organizer right click on Overwrite, click on create a new mod and call it Z-FNIS, activate the createt Mod. IMPORTENT Z-FNIS must be the last mod in your Loadorder)
Then open Bodyslide and Outfit Studio
Step 1: Under Outfit/Body chose CBBE Body HDT
Step 2: Under Preset chose what you want
Step 3: Then click on Build and click on Ok
Step 4: Checkmark the RacemenuMorphs option
Step 5: Click on Patchbuild and chose CBBE Body HDT click ok and wait and when its finished click ok
You are done
If you wanne use it i hope it works for you too, if you have any Questions you can Contact me (sorry for my bad English, i hope you understand the hole Guide)
Install Order:
07: RaceMenu
12: FNIS Behavior
Close FNIS.
You are done
Sinderion81 wrote:If you have installed these Mods, then start TES5Edit, deslect all Mods and select Remodeld Armor - Vanilla Replacer.esp
So ether my TES5Edit dont see the Enderal stuff or you mention the wrong races.
Edit:
Turns out I needed to reinstall Enderal, for some reason. So its working now.
But why do we need to add the races once more?
[RACE:00033898] and [RACE:00013748] are both showing as RedguardRace "Half Qyranian".
Same for NordRace "Half Arazealean", [RACE:00013746] and [RACE:00033899].
They changed the Ids for two races, and if you not change the id the Armor on the two new races are invisible
How do you get the Remodeled Armor mod from the HDT Comp to work with the (Aeterna?) race, every time i equip the items they don't have textures or meshes
Is there any way to patch Enderal clothing to CBBE ? I am not very familiar with these body slides. After following the instruction now all the clothing and armor ingame is converted to the ones in Remodeled Armors
Here is a list of mods I have for and use in Enderal and they all work--
1) Race Compatibility
2)Apache Hair (only works for character)
3)Apache Females (again, only characters)
4)Apache Male (only char again)
5) SexLab.esm ADULTS ONLY!!
6)SexLab Aroused (all work with everyone in Enderal) ADULTS ONLY!!
7)Schlongs of Skyrim-Core-(works with everyone in Enderal) Adults Only!!!
Skyrim Borders Disabled (Disabled walls and blocks where you couldn't go before)
9)RaceMenu
10)Race menu Plugin (Works good with detailing in skyui)
11)Dynasty Armor-(Sometimes works sometimes not)
12)SexLab Futunarium-(self-explanatory) Adults Only!!
13)SexLab Cumshot-(On orgasm) !!If Interested and for Adults Only!!
14)Lay Down
15)Sit Anywhere
16)Hug Me
17) SOS RaceMenu
18)SOSRaceMenuRotation
19)FootIKOff Spell
20)FNIS
21) SexLab Eager NPCs (Tracks Non important and Important NPCs for all kinds of things to do---sexually) ADULTS ONLY!!
22) Non SexLab Animation Pack ( Quite a few different moves if you know what I mean) ADULTS ONLY!!
23) SexLab necro (Like ghosts? Kind of liked the woman or guy bandit you just killed? Bring them back to use for your own uses, if you get my drift!) ADULTS ONLY!!
24) playable fix.esp
25) SexLab Tools- (Make your own animations and enter them into your game)
26)UIExtensions -(Necessary to use SexLab and/or SOS if any kind.)
27) Schlongs of Skyrim.esp ADULTS ONLY!!
28) SOS Equipable Schlong.esp
29) SOS Smurf Average Addon.esp
30) SOS B3Lisario addon.esp
31) SOS Leito Addon.esp
32) SOS Erf Whanger Add On.esp
33) SOS Equipable Schlong Enderal Patch.esp
34) Enderal Smurf Average Patch.esp
35) Enderal Leito Patch.esp
36) OSACT.esp ADULTS ONLY!!
37) FNIS Sexy Move.esp
38) FNIS Spells.esp
39) Bathing In Skyrim.esp (It does work yes)
40) dD-Realistic Ragdoll Force-Realistic.esp
41) Bikini Clothes.esp ( at first it didn't work but had to only use the Sharlikan Patch only. Seems to work ok for now.)
42) FISS (Need it for SExLab Eager NPCs.esp)
43) Child Follower.esp (Haven't tried this yet, but will let you know when I do)
44) Follower Limit Increased.esp
45)zzLSAR.esp clothes
46) Schoolgirl Outfit.esp
47) Console Books.esp
48) Remodeled Armor--Vanilla Replacer
Also I haveCBBE body replacer, a patch for it, and others I can't list because they're not on the launcher. But they work due to necessity. These all work except the two that I stated I haven't tried yet. I will let you know when I do. Later all.
9)RaceMenu
14)Lay Down
15)Sit Anywhere
16)Hug Me
17) SOS RaceMenu
19)FootIKOff Spell
20)FNIS
38) FNIS Spells.esp
@Sinderion81
Thanks for the guide as it's pretty much straight forward. I installed all mods in your list using MO, checked all the steps twice and things seemed fine until I got to the configuration in Bodyslide. In Bodyslide Step 1- I'm not seeing a "CBBE Body HDT" in the outfit list. Bounce and Jiggles CBBE CT77 HDT Only Body is installed. There are lots of CT77 listed in the "outfit/body" menu but no "CBBE Body HDT".
I'm probably too dense. Skyrim Bodymodding is one of the most difficult things to wrap my head around.
P.S. Ich kann dich auch in Deutsch zur Verzweifelung bringen mit meine modding Inkompentenz falls dir das lieber ist
greets
Gromic
EDIT:
fixed - load order
greets
Gromic
EDIT:
Hey!
How did you get Sexlab Eager NPCs to work?
It works for me only when I first enable it. Afterwards my game crashes everytime I load a saved game file.
Cheers!
Cheers!
20.08.2020 16:53marqisingh1 wrote: Hey!
Cheers!![]()
(we moved the thread from the archived part of the Forum)
i can't help you with your actual question, but most of the thread was written in 2016, and is really outdated.
the mod you're trying to use may be incompatible with the newer Enderal versions? check the date on which it was last updated
